E7-11 error
  • Leebs14
    • Feb 2014
    • 457
    E7-11 error
    I have a MXC300W showing a recurring E7-11 error intermittently, manual says CCD Fault, anyone agree or had this themselves?
  • bilyahn
    • Dec 2006
    • 1466
    Re: E7-11 error
    That is correct. Do a firmware update and a white reference adjust and see where that leads. I have a unit that just randomly throws one of these only when they scan, very annoying.
    Good luck.
    Bil
    • Leebs14
      • Feb 2014
      • 457
      Re: E7-11 error
      [QUOTE=bilyahn;1473831]
      • copiertec
        • Jan 2016
        • 2184
        Re: E7-11 error
        [QUOTE=Leebs14;1474214] Leebs, I looked on Sharp site for any E7-11 issues related to this mfp...nothing. I hate to ask the obvious, did you clean the glass and the white reference sheet? Check AC wall current, trace and check connections internally in the mfp, if you have another unit in the shop, try switching out the lamp, if that does not work your I think your looking at board issues.
        • 1stcavvet
          • Apr 2015
          • 231
          Re: E7-11 error
          flip the glass over and clean the white mylar on the end there are some small white tapes on the ends of the adf glass--- that might just be on the older sharps
          probably would't hurt to clean the fog off the exposure lamp --just run a rag over it that code is the machine having a hard time seeing white levels it's looking at that white strip
          • Leebs14
            • Feb 2014
            • 457
            Re: E7-11 error
            these models are not like thar, the scan unit is a whole unit and just to get the glass out is a full top end strip down, doc feed off and a whole host of covers and screws.thus machine has done 12K in an accountants office so cleM environment etc. I hate these little sharps I think they are crap
            • copiertec
              • Jan 2016
              • 2184
              Re: E7-11 error
              We have always used Kyocera for desktops as opposed to these Sharps. Sharp also makes the frontier series with a totally encased optical box, which is also a pain in the ass to dissemble to clean under the glass. Kyocera does the same thing with their tabletops, I don't know why thet do not make these optics accessible?
              • kdr363
                • Apr 2019
                • 63
                Re: E7-11 error
                My techs have replaced about a dozen CIS units for random E7-11 codes on the C300W. All of them were manufactured in July 2018. So, the first digit of the serial is 8 and the last digit is 7. I complained to my RSS and got some free units from Sharp. Yet, no tech bulletin about the issue.
