MX-M5070N admin password reset? No DSK
  • nathansipe
    just another tech
    • Aug 2009
    • 122
    I've reset many Sharp's over the years, but not the new lines. Does anyone have experience resetting the admin password for this series? There is no Data Security installed. I know the 465, etc was dipswitch 1 then 24-30. I'm not currently at our wholesale branch where this info is needed so I don't have eyes on the machine yet.
    I'm hoping I don't have to call Sharp, like some forum's have suggested, as we are in a time crunch. Thanks in advance!
    Best rule for troubleshooting.
    K I S S Keep It Simple Stupid
  • spanky
    • Sep 2012
    • 468
    Re: MX-M5070N admin password reset? No DSK
    See attached
    • xordi69
      • Jun 2010
      • 200
      or change the msata....
      • jon jennings
        • Aug 2011
        • 51
        Go to another machine (MX 5141) model doesn't matter. Go to Storage backup. Choose User Register Information. Create backup. Go to the MX 5070, type IP address. Go to (IP address /service_login.HTML), Password is service. Go to device Cloning. Send the backup you made to the machine and the password will be reset.
        • JLSam
          • Jun 2015
          • 605
          You!... I like you. I will put this to the test.
          • JLSam
            • Jun 2015
            • 605
            Confirmed.
            (I think we should keep this Lo' Key though, we don't want Sharp Corp to change this in a firmware update...)
            • meszi
              Originally posted by JLSam
              Confirmed.
              Will it delete all other user created, or just overwrite the admin password? i have a sharp with about 80 users created, and don't wanna recreate all of them if possible
              • nobody-here
                • Mar 2008
                • 237
                Is there any way to do the clone trick, with "Service" password modified?
                Or how to reset "Service Password"
                29 rouge unpair manque.... cous cous....
                • ctuinstra
                  • Apr 2011
                  • 49
                  Short answer, yes! You will need to open the XML file and strip out all of the other information but just the password and it tags. Have to understand XML in order to do it correctly, you can easily corrupt the file. I do this with our standard clone file so we can update any customer machine with our standard configuration and not have to worry about changing anything we don't want changed.
                  • jon jennings
                    • Aug 2011
                    • 51
                    You can send the clone with 56-02 also.
                    • dmary
                      • Jun 2017
                      • 20
                      Good evening,
                      thanks for the tip. I edited my user registry backup file leaving only the admin account. It allows me not to touch other accounts.
                      If the administrator password and the service password seem to have changed. There may also be a faulty hard drive problem.
                      French technician since 1994. Thanks to Google Translator for helping me to make myself understood by you.
                      • havokprod
                        • Oct 2012
                        • 156
                        Grave digging here but this also works on DSK machines. Thank you Jon Jennings!!!!!!!
                        • Prestige3613
                          • Apr 2015
                          • 14
                          Genius. Worked like a charm!! Thank You!
                          • bilyahn
                            • Dec 2006
                            • 1466
                            Happy Thanksgiving to everyone!
                            Just got back from a class and if you are a sharp dealer they have made it really easy to reset the admin password. Go into your IDNC Service website then your Calls list and there is a tab to reset admin password there. Haven't tried it yet.
                            Good luck
                            Bil
                            • JLSam
                              • Jun 2015
                              • 605
                              Good luck
                              Bil
                              I just saw it, cool but...
                              "The normal turnaround time is 2 to 3 business days."
                              That is still too long for my taste.
