Showing N9 on ESP surge protector
  • Dcopyman
    • Apr 2020
    • 34
    [Electrical] Showing N9 on ESP surge protector
    I have a MX-5070N that is powering down and restarting frequently. I have replaced Msata, and installed an ESP surge protector. The ESP displays N9 ( >=4vac between neutral and ground) and also records low voltage errors. The customer has had an electrician come out and check outlet, only to say he saw no issues with outlet. Going to try replacing DC Power Supply PWB today, but wondering if any one out there has had any issues like this and remedy. TIA
    • 16309
    Re: Showing N9 on ESP surge protector
    Have you checked the outlet with a volt meter? I would check it under load.
    • Dcopyman
      • Apr 2020
      • 34
      Yes I tested with meter (crappy one) under stress and so did the Electrician.
      • kdr363
        • Apr 2019
        • 63
        Sure sounds like red flags when the surge protector isn't happy and the machine isn't happy either. Have you got a voltage regulator to try on it for a period of time? Tripplite LC1200 or ESP SE-15 sag eliminator
        • Dcopyman
          • Apr 2020
          • 34
          kdr636.... Do you have any first hand experience with either one, and if so which would you say does the job better? I looked up prices quick and found one was around $162 msrp and one was $562 msrp. I'm sure I could find them cheaper since one of them is available through Hytec
          • kdr363
            • Apr 2019
            • 63
            The tripplite is much cheaper and works just as good. But, it does make a "click" noise when the wall voltage drops below a certain level. Someone sitting near the machine may get annoyed, but points out a voltage sag or other voltage probs.
            Our area is terrible about wall voltage issues and we have had to resort to line conditioners often when customers refuse have it fixed properly.
            • Nachoman4life
              • Oct 2007
              • 212
              Try direct to the wall for a week or so, some surge suppressors, are the problem, its a one week idea to check
              Where the heck is my spring hook?
              • Dcopyman
                • Apr 2020
                • 34
                Installed a Tripp-Lite LC2400 today..... we'll see if it helps with the power issues!!!!!!!!!
                • ntbann
                  • Jan 2012
                  • 622
                  If you have 4 volts between neutral and ground there is a problem with the circuit. It should be less than 1 volt.
                  • Dcopyman
                    • Apr 2020
                    • 34
                    Actually on Newer Sharp copiers, anything over .5VAC is too much between neutral and ground
