Ar 6020 scanner and printer disconnected
  • Latruns
    • Jun 2021
    • 18
    [Electrical] Ar 6020 scanner and printer disconnected
    Hi, this machine Ar 6020 have been working perfectly, one day the customer forget to removed the plug from socket unfortunate for him a loud thunder strike an destroy many things in the office and since that day the machine not connected to the system again. I try to reinstall the driver many times not connected anymore but the photocopy working fine please any help I will be glad
  • ntbann
    • Jan 2012
    • 620
    Re: Ar 6020 scanner and printer disconnected
    Can you ping it? Sounds like the NIC is blown.
    • Latruns
      • Jun 2021
      • 18
      No sound at all completely off, you mean plug and play sound. Thanks for ur respond
      • 40yearsplus
        • May 2020
        • 114
        You can't be a tech. but he means the Network Interface Controller where the ethernet plugs in.
        A ping is a message sent to it from a computer in the command mode that sees if the printer is there with the internet protocall address.
        If the Network Interface is integrated to large board. The whole board may need replacing.
        The details are too much to help you on the forum and your level of expertise not to offend you.
        Call a Dealer on the product and pay him to help you.
        • Hansen88
          • 1032
          Try printing directly from your laptop to determine if the problem is with the machine or the customers network.
          • ntbann
            • Jan 2012
            • 620
            Banging my head on my desk! Sometimes I wonder why I try!
            • spanky
              • Sep 2012
              • 468
              If you check his profile, the last copier he was trained on is over 30years old.
              • Latruns
                • Jun 2021
                • 18
                Originally posted by 40yearsplus
                You can't be a tech. but he means the Network Interface Controller where the ethernet plugs in. A ping is a message sent to it from a computer in the command mode that sees if the printer is there with the internet protocall address.If the Network Interface is integrated to large board. The whole board may need replacing.The details are too much to help you on the forum and your level of expertise not to offend you.Call a Dealer on the product and pay him to help you.
                Thanks for your response actually the machine is not ping that is reason why i quote(the sound completely off) may is the reason you're not get me right. I av change the interface controller this same thing,until I replaced the main board. The issue is I av the same fault wit another machine I sold that not quite long ago that is why I ask for help . Thanks
                • Latruns
                  • Jun 2021
                  • 18
                  Hello friend we don't need to embarrass our self before you render help even if someone is not an engineer you av ways to respond to him thanks
                  • Latruns
                    • Jun 2021
                    • 18
                    Sir you don't need to bang your head first the fault is not too big to ask and in my country there I no stable light, no thunder arrestor, we are facing many fault due to bad light and so on. Just relax I might not with stand some of you but am also respected. Thanks
                    • Latruns
                      • Jun 2021
                      • 18
                      Thanks am really appreciate already do that the problem come from main board unit the question is maybe it av way to revive it thanks.
                      • Latruns
                        • Jun 2021
                        • 18
                        No even try it with another system no sound. Thanks
                        • Craigcul
                          • Aug 2017
                          • 66
                          That machine has a separate NIC board AR-NB7 replace that and see if the machine is ok.
                          Sent from my iPad using Tapatalk
