Sharp MX2651 - ARM processors trouble with drivers
  • blackpanther
    • Nov 2017
    • 16
    Hello,
    We have problems with some clients that are working on devices with an ARM processor (such as the Microsoft surface Pro).
    The drivers won't install, the printer isn't showing up in the list or isn't working.
    We already tried the following drivers, without any result:
    • PCL6 / PS / PPD Drivers
    • SHARP UD3 Driver
    • SHARP V4 Driver
    Thanks in advance for any suggestions.
  • Prints Charming
    • Aug 2019
    • 189
    Re: Sharp MX2651 - ARM processors trouble with drivers
    Copy/paste the unzipped PPD Folder onto the Surface Pro. Run the manual 'Add Printer' method of installing the printer, and browse to the PPD Folder when prompted.
    There is no ARM Processor driver support, but operational & general print functions can be installed with the above method only. PPD is the only folder which needs to be transferred onto the Surface Pro. This is the only driver which will work.
    You could also use Sharpdesk Mobile from Windows Store. It's a different process to print a document, but it does also work.
    • blackpanther
      • Nov 2017
      • 16
      PPD driver didn't do the trick. Going to try the sharpdesk mobile option
      • Prints Charming
        • Aug 2019
        • 189
        You must use the PPD Driver with WHQL Certification. If you use the non-WHQL PPD driver it definitely fails on install.
        Double check you've got the correct driver.
        • ihatefinishers13
          Senior MFP Technician
          • Feb 2020
          • 613
          I asked our Sharp DSS about this in June of 2023, and he said there is no plan for Sharp to support ARM processors... Which I understand because there are so few, but they still support 32-bit stuff, even though there are so few.
          • Prints Charming
            • Aug 2019
            • 189
            There's now a ARM supported driver for Win10 and 11 called the UD3L (Universal Driver 3 Lite).
            It is similar to the UD3 driver, but has more features disabled. However, it supports ARM processors.
            • ihatefinishers13
              • Feb 2020
              • 613
              This a Sharp driver or Windows?
              We had a customer( that had a laptop with an Arm Processor, AND he wanted authentication on, so he has to use Sharpdesk Mobile because authentication with different user codes isn't possible with the PPD driver that works for basic printing.
              • JLSam
                • Jun 2015
                • 605
                Originally posted by kevin32305
                哪邊可以下載,謝謝
                Sharp Global:
                - | Sharp Digital MFPs / Printers
                • Michko
                  • Sep 2010
                  • 25
                  Where did you find these drivers?
                  I can't see then anywhere
                  edit
                  it works with HP Smart Universal Printing Drivers V4 ARM64
                  • Copyguy69420
                    • May 2024
                    • 36
                    I had the same issues with a arm device trying to print to a sharp copier and i used the UD3L driver for arm and it worked like a charm. If you are an authorized sharp dealer you should have access to sharp service success center. Once you log into that you want to go into Service Tools and in service tools you want to go into software library. In software library you want to type in ARM. Once you do that you want to you want extract the file and then do the basic install and should be straight forward after that.
                    • ihatefinishers13
                      • Feb 2020
                      • 613
                      I love the fact that Sharp never even mentioned that driver as an option... Also would have been nice if it was under print drivers, not software.
                      • sharphead
                        • Aug 2009
                        • 285
                        Is the UD3L still avaliable? I'm looking in Sharp UK and cannot see it
                        • Sven94
                          • Sep 2023
                          • 28
                          Here is the UD3L Driver
                          • Copyguy69420
                            • May 2024
                            • 36
                            Yeah i found it annoying as well.
