SHARP V4 Driver
  • boutn
    • Jun 2016
    • 537
    SHARP V4 Driver
    Driver Downloads - Find drivers - | Sharp Digital MFPs / Printers
    Has anyone tested this V4 driver?
    This to remedy the Microsoft Printing Nightmare update.
    Printing works fine, the problem is that serveral .TMP files are beeing created in the spool folder for every print.
    So every print makes a .SHD and a .SPL file + 6 or 7 .TMP files.
    Some of these files are 0kB and get deleted after 1 or 2 minutes.
    The rest does not get deleted...so fills up the folder.
    I've tried the Lexmark V4 driver, and this driver does not do that...
    Any solutions? (exept for a script that deletes the files periodically)
  • WackyJack
    • Feb 2021
    • 82
    Re: SHARP V4 Driver
    I have had 0 luck with the V4 driver from any manufacturer. They all tell me that the model is unsupported, regardless of how new or old the model is or what Operating System I'm trying to install it on
    • Vincent128
      • Sep 2015
      • 341
      Re: SHARP V4 Driver
      V4 == junk
      Use proper driver from the manufacturer.
      • Prints Charming
        • Aug 2019
        • 189
        Re: SHARP V4 Driver
        The Type4 driver isn't the remedy for Print Nightmare. Several Microsoft Updates must be removed, particularly September/October/November 2021. Plenty of info on this online.
        Make sure the 'Keep Printed Documents' check box is not ticked within Properties - Advanced Tab. This will cause SHD and SPL files to be retained so the job can be resubmitted if there is an interruption.
        If that is not ticked, it would be suggested to remove & reinstall the drivers. Better yet, install the actual manufacturer release WHQL certified driver. You might also be getting temp files retained in the spool folder if the document requires PS drivers. Type4 is PCL.
        Type 4 drivers were introduced by Microsoft with Windows Server 2012, and were intended to replace the default drivers bundled with Windows OS. There are many limitations on Type4 compared to the manufacturers Type3 driver, which is the recommended driver. Type4 was primarily designed to make sharing easier and more efficient by eliminating the need to manage different drivers across different processor architectures, eg, to make the life of poor IT Managers much easier.
        • boutn
          • Jun 2016
          • 537
          Re: SHARP V4 Driver
          Removing updates who resolve a major vunerability on a server is maybe not the best idea...
          There is a workaround with adjusting the GPO and then you can use the type3.
          The question was about the TMP files...
