I have had orders for the MX-601FB and MX-601LH for over a month and still says "ON ALLOCATION". Are there others having the same issue? Hard to keep customers happy. Does anyone know what the problem is? I would sure like to know. Thanks Ron
Fuser units for MX-3051 series
Re: Fuser units for MX-3051 series
We interchange Phoenix 1 and 2 supplies with absolutely no issue. We still keep the higher speeds separate, though.
Hope this helps
601FB=CFRM-1726DS73 (30/35/40ppm)
602FB= CFRM-1726DS74 (50/60ppm)
601LH=607LHComment
We have indeed experienced delivery problems for a long time, especially with the 601LH. In addition, we also have many problems with the 601LH, which always gets wrapped around paper after a while. We therefore switched from the 601 (and 601FB) to the 607 (and 600FB) for the MX-409FU.Comment
ron67601
I still have some that fail with the 607 fuser belts and lower rollers. Should I also set the paper to 24+ - 28 in the paper tray settings? That will raise the heat up right? ThanksComment
we did that at the beginning. we are only using 601lh and 601fb now to limit stock quantities. also the bulletin about adjusting the temp (TT-070918_1) might help? but i've never really seen it do anything.I fix copiers ...Well SortaComment
