Just a quick question about the waste toner boxes on MX-3050, 3070, and 5050. I've been having lots of these fill up without shutting the machine down. The tab is in the up position and what happens is the toner backs up in the drum unit and locks it up. I have checked the bulletins and can't find anything on this. Has anyone heard of this and can tell me what the fix is? Thanks Ron
Waste toner boxes
Re: Waste toner boxes
I have 2 or 3 units that do what you describe.
One is at a CBD manufacturing place and they use mostly Yellow, so the yellow gets backed up when the "Prepare waste toner" message has been on for awhile.
Locks up and breaks the process unit.
Although not a fix, I have asked them to change the waste container as soon as it says "Prepare waste container".
Seems to help in the meantime.
Just a quick question about the waste toner boxes on MX-3050, 3070, and 5050. I've been having lots of these fill up without shutting the machine down. The tab is in the up position and what happens is the toner backs up in the drum unit and locks it up. I have checked the bulletins and can't find anything on this. Has anyone heard of this and can tell me what the fix is? Thanks RonComment
The waste toner container is not inserted all the way and the auger can't get into the waste toner container. Therefor the auger backs up and from friction the toner hardens and takes out the process unit.Comment
