Sharp MX B402SC Density Adjustment
  • cucuklotz
    • Mar 2007
    • 611
    Hey Everyone
    Thank you ALL AS AWAYS for offering help. I ended up just having the customer manual set the exposure to a darker setting for all copying(Both on the glass and thru the ADF.
    I tried to adjust the exposure settings for the Automatic Exposure to darken up the print thru the simulations(USING SIMULATION 46)I gave up after 2 hours as nothing seemed to work .
    I am not sure Exactly which 46 subcode to use and how to set it(YES I HAVE THE SERVICE MANUAL). Please help as I am probably missing the easy way to make this adjustment and yes I will say the obvious for all
    I HAVE NO EXPERIENCE USING THIS SIMULATION ON THIS MACHINE
    IT USED TO BE SO EASY 25 YEARS AGO
    Thank you for your patience with me as always
    Andy
  • driving lots of miles
    • Jun 2016
    • 391
    Re: Sharp MX B402SC Density Adjustment
    Have you cleaned the glass and mirrors in the LSU. Although is has been a couple of years ago I had a B402 with light copies and that made a big difference.
    • kdr363
      • Apr 2019
      • 63
      It's much easier to use system settings/copy function settings to adjust default exposure. Otherwise, sim 46-2.
      • ZOOTECH
        Senior member of CRS
        • 3378
        Make sure the customer has not set the machine to Toner Save; density adjustments look great in SIMS, but will be faded in use in copy mode (not sure about Print mode).
