BP-FN11 code F1-22
  • ron67601
    • Apr 2025
    BP-FN11 code F1-22
    Hey guys, I have unboxed a couple of new machines with inner finishers and shortly after installation they have gotten F1-22. One I sent back under warranty. Has anyone else been experiencing this problem or is it just my luck. Thanks and I appreciate your response Ron
  • bigdaddyooo
    • Dec 2014
    • 211
    Re: BP-FN11 code F1-22
    I have. 5 FN11's installed and 3 had F1-22 shortly after install. It's maddening. Then I ask Steve...hey have you heard anything on the FN11's? NOPE...wtf
    Are you the police? "No ma'am, were musicians"
    • ron67601
      I have installed new ASM-ASSIST units in the ones that coded out. So far they are working. Asked my RSS from Sharp about it and he just stated it could be grease on the sensor or the unit itself. Good luck
      • nanohitmen
        • Apr 2019
        • 108
        I had a couple of BP finishers that came with the cables not properly inserted from the factory. they were coding out a lot.
        • chatkal
          • Aug 2015
          • 47
          Terrible finisher. We have issues with them all the time.
          • ron67601
            And Sharp says they haven't heard about this problem when they are asked. I agree with you lousy finishers.
            • OlliK1969
              • Nov 2016
              • 309
              Hi
              there is a service information CCE-3005 from Aug. 29, 2023
              - BP-FN11/FN12 (Option for BP-60C31/60C36/60C45/70C31/70C36/70C45/70C55/70C65, BP-50C26/50C31/50C36/50C45/50C55/50C65/55C26, BP-70M31/70M36/70M45/70M55/70M65, BP-50M26/50M31/50M36/50M45/50M55/50M65)
              2. Subject: CHANGE OF ASM-ASSIST
              3. Phenomenon:
              When the excessive load is applied to the guide and pawl in ASM-ASSIT at the time of outputting the paper, the shaft that maintains the belt tension falls, and becomes unable to maintain the belt tension, which may result in the following troubles: ・Finisher Paper Bundle Exit Operation Trouble (Trouble code: F1-22) ・Assist Motor JAM (JAM code: FNM5)4. Description: Modification has been made to the peripheral parts of the belt tension plate in ASM-ASSIT to support the above troubles. Along with above change, the part code of ASM-ASSIT has changed. Location (Excerpt from Parts Guide of BP-FN11 series 11 Disposition tray section2)ASM-ASSIS
              • ron67601
                Just checked on the website and can't locate CCE-3005. Where did you find it? Thanks Ron
                • Rickybobby
                  • Jul 2019
                  • 2
                  Hey guys,
                  This may help-
                  • OlliK1969
                    • Nov 2016
                    • 309
                    Hi
                    here is the technical report
                    • ron67601
                      Thanks, really appreciate that. Ron
                      • ron67601
                        Another thing Ollik1969, where did you find that if I may ask. It doesn't pop up in Bulletin search even though Service Information is listed there. If you are someone on here could pass that along it would help. Thanks Ron
                        • OlliK1969
                          • Nov 2016
                          • 309
                          Hello
                          I found it in Knowledge Management at Sharp. Sharp's search function is rubbish/garbage . Once a week i look there, what is new.
                          • ron67601
                            Another question, what site is that on? Can't seem to locate on the service site. Is it a different website? Thanks Ron
                            • OlliK1969
                              • Nov 2016
                              • 309
                              Hi
                              This is our Sharp Germany access, for all Sharp dealers.
                              I actually thought everyone had this access...
                              SharpONE
                              Dashboard
                              Advertising Materials
                              My settings
                              Training information
                              Video database
                              Download Center
                              Videos technical support DS products
                              Photo database
                              These areas are there
