Sharp MX-5140n error Code: U1-01. Forward the incoming fax data
  • abbey
    • Aug 2023
    • 3
    I have a sharp mx-5140n printer that's showing error code: U1-01. Forward the incoming fax data. Please how do i solve the problem?
    I've tried using sim 13 and 14 but the error is still showing. What else can i do please? Thanks in advance.
  • copiertec
    • Jan 2016
    • 2184
    Re: Sharp MX-5140n error Code: U1-01. Forward the incoming fax data
    Replace the battery on the main board.
    • abbey
      • Aug 2023
      • 3
      Thanks for the answer. I really appreciate it.
      I'm a novice, any guide on how to do this and any further info about this battery will be much appreciated.
      Once again thank you.
      • copiertec
        • Jan 2016
        • 2184
        The battery is located on the MFP board (same board the fax is connected to) its a removable battery, replace it with any brand that is the same size.
        • abbey
          • Aug 2023
          • 3
          Thanks so much.
