I am very puzzled about this one. I am getting H5-01 errors on several M4071s. Usually I get this code after 5 jams in the fuser, but with these machines I am not getting any jam and the 23-2 shows no jams at all. I have replaced the POD-1 sensors just in case and the firmware has been updated to the latest version. Reding the manual I find this code can also be caused by a fuser wrap jam, but I never see any of those either. Has anyone else seen this? Does anyone know how the fuser wrap detection works? I can't find that information in the manual. Any help would be greatly appreciated. Thank you!
H5-01 on MX-M4071
Re: H5-01 on MX-M4071
We had a lot of trouble with the M4070 series.
I could take one fuser that coded out frequently with H5-01's and install into another machine where it had no problems at all.
I also had rebuilt that same fuser and installed new jam sensor, but it failed to work properly in the original machine.
My theory is that it has to do with the insertion depth of the male side of socket into machine side female receptacle. I think the frame tolerance might be off, requiring extension of fuser-side.
Cleaning the socket pins seemed to work temporarily but not a permanent fix. I believe the code comes from pins losing connection, not due to jams but randomly during operation. Other codes would appear as well, infrequently.
Try switching fusers between a couple machines if possible, you might get lucky like I did on few. -
I am very puzzled about this one. I am getting H5-01 errors on several M4071s. Usually I get this code after 5 jams in the fuser, but with these machines I am not getting any jam and the 23-2 shows no jams at all. I have replaced the POD-1 sensors just in case and the firmware has been updated to the latest version. Reding the manual I find this code can also be caused by a fuser wrap jam, but I never see any of those either. Has anyone else seen this? Does anyone know how the fuser wrap detection works? I can't find that information in the manual. Any help would be greatly appreciated. Thank you!Comment
I forgot to mention that I cleaned the contacts and even bought the insanely expensive cleaning swabs from sharp. This helped with the other random fuser errors, but this H5-01 persistsComment
Just a FYI, these work and are much less expensive.
The Puritan 3130 is a 2.71" long microfiber applicator with 0.39" tip. With high quality cotton over the foam, the lint-free and residue-free applicator is used to apply adhesives or to remove contamination.Puritan 3130 Specifications: Product Type: Applicator Material: Microfiber Material Category: Plastic Head Length: 0.39in Head Width: 0.13in Handle Length: 2.71in Handle Width: 0.08 Diain Overall Swab Length: 2.71in Standards Met: FDA GMP's Compliant Package Quantity: 100BG Package Quantity1: 10BG/CA Package Quantity2: 1000CAComment
Replace fuser unit with a new one to test the machine.
Good luck.
AndyComment
