Paperjam but no paper
  • glimmer1980
    • Aug 2014
    • 103
    Hello,
    I went to a customer site that has a MX-3071 with the message on screen that states that there is a paperjam. I checked everywhere, but couldn't find any piece. I checked the sensors and they all work. When i checked 22-3 the error code P_ON was there. I changed the fuser which i thought maybe that there was the problem, but no. I'm not sure where to look next. Does anyone have any ideas?
    Regards,
    Ramon
    • 16309
    Re: Paperjam but no paper
    Originally posted by glimmer1980
    Hello,
    Regards,
    Ramon
    Can you explain what you mean when you say that all sensors are working? Do you mean mechanically and electronically?
    • glimmer1980
      • Aug 2014
      • 103
      I checked through simulation codes 30-1 / 30-2 / 4-1 / 2-2 the sensors if they react or not.
        • 16309
        That's the correct way. Just to be clear, you manually activated every sensor and it changed states on the LCD screen? If so, I'd say that you have some type of board problem At least that the only thing that I can think of.
        • glimmer1980
          • Aug 2014
          • 103
          That's correct. I manually checked the sensors and they work.
            • 16309
            This may be worth a shot. Disconnect every option -doc. feeder, finisher, ect- and see if the paper jam goes away.
            • glimmer1980
              • Aug 2014
              • 103
              I will try to do that and see what happens. I will let you know
              • copiertec
                • Jan 2016
                • 2184
                P codes generally relate to paper exit issues, you have swapped the fuser which has the POD 1 sensor and flag on it, my next suggestion would be to remove the exit assembly and see if any of those sensors are out of place. also, I am not familiar with you machine but I have seen instances where the right tray (fax tray) is activated and there is no right tray and every time you receive a fax it jams at POD 3. Also, check your PPD 2 sensor and make sure there is no paper dust blocking it.
                • ron67601
                  Had one the other day on a MX-4071 that showed PRI_JAM and would never print a copy. They had a fax attached and I cleared 66-10 and it still failed. Cleared 67-17and that took care of the problem. Might try them can't hurt. Good luck
                  • mloudy
                    • Oct 2015
                    • 761
                    Make copies with the misfeed sensors disabled. SIM 7-1. See if will pass paper.
                    • glimmer1980
                      • Aug 2014
                      • 103
                      @mloudy. What does sim 7-1 exactly do. The manual says that 7-1 is "Used to set the operating conditions of aging"
                      • Hansen88
                        • 1046
                        Hello,
                        Regards,
                        Ramon
                        I had a problem exactly like that. Same code. In my case is was a bad surge box. Machine would periodically reboot then give that code. I changed the box and problem went away. Hope this helps.
                        • glimmer1980
                          • Aug 2014
                          • 103
                          I finally found it. There was een piece of paper stuck in the exit unit. Because they have a internal finisher it was hard to see. Thank you all for thinking along.
                          Regards,
                          Ramon
                          • mloudy
                            • Oct 2015
                            • 761
                            I think if you use Misfeed Disable-JAM detection ingnoring setting in 7-1 it will pass paper and ignore the state of misfeed sensors. In this case it would have either pushed that little pice of paper through or stopped because the piece of paper blocked the path. Either way you may have been able to find it quicker.
                            • nejcos
                              • Sep 2014
                              • 6
                              I manualy set the paper so it said misfeed, then tried SIM7-1 disable missfeed, machine rebooted and nothing happened, jam was still there.
