Have a machine that has a C4-20 and the black usually looks washed out. Intermittently, I have seen the magenta and cyan washed out, as well.
The harnesses look fine. I replaced the PCU PWB, TC PWB, MC PWB and PTC unit. I swapped out the primary transfer unit, replace the B1, TL, U2 and rebuild black process unit. Same issue. I have only replaced 1 of the 2 TURC clutches, because I broke the 2nd clutch.
Sharp tech he does not believe it is the clutches because it is more for color, which I am not so sure of.
Any help would be appreciated.
