Out of my element with this printer but live extremely rural so hiring someone to check it out isn't an option. Will either fix it or get rid of it if I can't...
Picked up this sharp printer that had an error code on it, quickly fixed that with a new fan. Printed fine for a couple copies and started ghost printing.
What I have done: tried cleaning the transfer belts and that didn't fix it along with regular maintenance with the attached cleaning rods on the inside cover. Was only printing black so tried black drum next, still no luck. Tried to get a new cleaning blade for the primary transfer unit and that did not work either. Also tried changing paper type as well as weight in the settings and using a different type of paper.
During this period I replaced color toner cartridges and ran a color test print and saw the ghost issue is not just on the black but all colors. Also red prints with a yellow outline, was going to try and color calibrate but it will not read the scan with the ghost printing.
Last thing I tried so far was to pull all drums and clean the blades to see if that would help temporarily, it did not. I ran a copy of a blank sheet for 50 copies and every single one had bad streaking or color from the color test.
It would seem that the transfer belt isn't getting cleaned but I'm not seeing any issues with the belt itself so thought the cleaning blade would be adequate.
I have primarily worked on eco solvent printers, so quite a bit different and this one is just for personal use to print kids schooling materials. Any help would be appreciated. I have the service manual but didn't find anything that specifically addressed this issue.Screenshot_20231005_180327.jpg
