Sharp MX 3071 Setup
  • tthomas@ttronics.com
    • Dec 2023
    • 6
    Sharp MX 3071 Setup
    I have a customer that bought a Sharp MX 3071 that was never setup. I'm setting it up for him and get a L4-11 code. From what I can tell I have to install a exit cabinet or a finisher.
    I can not locate exit cabinet MX TU16, is there a work around or a new part for this setup?
  • driving lots of miles
    • Jun 2016
    • 392
    Re: Sharp MX 3071 Setup
    My employer has mentioned to me that the exit cabinets are impossible to get. We have had several trade-ins but they all had the inner finishers.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 611
      Yeahhhh you're doomed. You'll need to find an MXTU16 exit unit or an MXFN27N finisher and install it. We bought a few finishers from an equipment broker, because we had a few machines without.
        • Dec 2023
        • 6
        Yea that's what I figured, I did see someone mentioning taking motor assembly out of a BP kit, not sure what they were talking about. I'm a Toshiba dealer, but doing this for a contractor that did some work for us.
        • JLSam
          • Jun 2015
          • 605
          Psst, you, yeah you, come here... here you looking for some TU16's...
          Listen my guy... there is a way... but it costs.... 3 times the price ok?
          It's pricey... but I got you... you see, all you got to do is...
          BUY THE PARTS INDIVIDUALLY.
          Makeshift TU16 without screws cheat sheet:
          GCAB-1616FCZZ BD GJ D Delivery tray cabinet
          LSOU-0274FCZZ BA FX D Delivery tray
          LSOU-0278FCZZ AR EQ D Reverse gate tray
          LFIX-0627FCZ1 AD DJ C Paper fixing arm
          MLEVP0960FCAZ AD DJ C Full detect actuator
          PCOVP2711FCZZ AE DS C Shifter motor cover
          MLEVP1340FCZZ AD DJ C Shifter unit slide lever
          QEARP0396FCZZ AD DJ C Shifter unit drive earth plate
          NGERH2492FCZZ AE DJ C Shifter unit reduction gear(24/50T)
          CPLTM9050FC01 AG DX C Shifter unit drive plate
          RMOTS1067FCPZ AY FQ B Motor
          Courage guys. Where there is a will, there is a way.
          • ihatefinishers13
            • Feb 2020
            • 611
            Originally posted by JLSam
            [ATTACH=CONFIG]60785[/ATTACH]
            I really hate Sharp for doing this. Also, you might want to add in what the finished result is supposed to look like... Not everyone enjoys Lego's, but I don't associate with those types of people anyway :P
            • JLSam
              • Jun 2015
              • 605
              Looks good, functional and it works.
              We just keep a set it stock, and we have been using inner finishers. But sometimes we use it when an inner finisher is unavailable, or the end user doesn't need or desire it on the small upsell.
              I didn't add the screws there, because we have a sh*t ton of screws, so, you would need to go through the parts guide and get them yourselves.
              Works great though!
              • mloudy
                • Oct 2015
                • 762
                Will a BP-TU10 work? Wrong color but it might not have any changes from the TU16 other than color.
                I'd try buying a BP-TU10 for the shifter motor assembly and then if you want a color match order the clear tray and bottom tray from a MX-3071 Parts Guide.
                The clear tray on the BP-TU10 is not the same as the clear tray on a MX-TU16. It will not screw on a lower gray tray of the part ordered from the 3071 Parts Guide.
                • mloudy
                  • Oct 2015
                  • 762
                  This should be everything you will need to recreate a MX-TU16:
                  BP-TU10 (this provides the shifter mech, paper full arm, reverse gate and paper fixing arm)
                  GCAB-1616FCAZ
                  LSOU-0274FCZZ
                    • Dec 2023
                    • 6
                    Thanks for the info, I'll either do that or go with an inner finisher.
                    • mloudy
                      • Oct 2015
                      • 762
                      If this copier had a finisher installed at some point you will also need to get your hands on the foam rings that go on the exit rollers of the shift unit.
                        • Dec 2023
                        • 6
                        Machine was never setup, if I go with the MX FN27N inner finisher, is this all I will need; no other kit needed to get it going?
                        • mloudy
                          • Oct 2015
                          • 762
                          Nothing else needed. If you need the Installation Guide let me know.
                          • JP1
                            • Jul 2012
                            • 7
                            Temporary Measure Sim 55-01 SW24-7-1 (1 disable) will get paper out without the code L4-11
                              • Dec 2023
                              • 6
                              Where can I get firmware download, so I can update the machine when installing the finisher? The machine is a few years old and has never been setup, so I figured the firmware needs updating.
