MX-2310U not booting
  • euyulio
    • Feb 2024
    • 8
    Hi all, I think I have a corrupted SD card, would somebody be so nice give me a copy?
    When i start printer after the logo animation I get this:
    after some seconds i get this:
    and it stays like this...
    Thank you in advance
  • mojorolla
    The Wolf
    • 2571
    Re: MX-2310U not booting
    [ATTACH=CONFIG]61780[/ATTACH]
    [ATTACH=CONFIG]61779[/ATTACH]
    Looks like machine is in Emergency Update mode. There is a very small dip switch on the MFP board which turns this feature on.
    There are a few threads on this forum, with picture, that will point you in the right direction.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 626
      I think it's actually right next to the SD card, if I'm not mistaken. Could have been hit by mistake
      • euyulio
        • Feb 2024
        • 8
        Thank you very much for your reply, the switch was in off position, if I turn it on, the screen goes from black direct to "update program init" if i leave in off it shows the animation and then goes to "update program init"
        I tried to read the card on windows and mac both says "not initialized" with a partition software says it is empty... I guess it got corrupted
        • euyulio
          • Feb 2024
          • 8
          THank you very much for your reply, yes it was exatly there but the machine was closed when it happened and nomobdy has opened it. I tried to move both switches and no change (it was in off) when i put it on it goes from black screen to the update screen if I leave in off it shows the start animation then goes to the update screen. I think the sd card is corrupted because it has no content, partition software says no bytes are been used.
