AR-M450 PCL5e Staple Option Not Available When Printing
  • mtbcpa
    • Apr 2025
    I have an office network printer/copier that is an AR-M450 PCL5e. Some individuals using the printer can select to have the output be stapled, but others don't have this option. How do I configure this? Thanks for your help!
  • OMD-227
    The users who cannot use the finisher functions, have an incorrect PC Driver configuration. It has most likely defaulted back to the original settings (eg, without options fitted.... trays/desk, finisher etc etc).
    Go into the driver properties on the server or the local PC's if no server, run the Auto Configuration button under the Configuration Tab. This will reset everything back to the right machine config.
      • 22921
      Thanks, wazza. I couldn't remember the exact keystrokes.
      • OMD-227
        No worries Boss!!
        Its hard beating you to answering most posts!! You're always on the ball mate!
        • spotlifter
          • Mar 2008
          • 65
          If my memory surfs me right, ARM450 doesn't support auto configurations. You have to manually key-in the optionals. ARM455 does support auto configurations.
          sigpic
          • Dark Helmet
            • May 2009
            • 829
            It does support Auto config IF you have the printer monitor installed which most people don't so.
            1) Go to printers and faxes, Right click properties
            2) Configuration Tab and start clicking the radio buttons and make the picture in the screen match the copier on the floor
            (3 tray desk vs LCT. Mail bin Vs Finisher, Check off if you have saddle stich. All this information the config tab asks can be found from the list print on the machine. Key Ops, List Print, All custom settings list)
            3) Hit Apply and your laughing. If you have the LCT Trays make sure you change your printer defaults to go to the LCT instead of Tray 1
