Guys, Gals,
I have a Sharp AR-M355N copies with the AR-FX12 fax expansion unit. In the past, I have been able to access the web interface, but now I can't. The network scanning works fine and I can ping the copier from the network. I can even ftp:// into the copier and see the /lp folder, but I cannot access the web settings with http://ip.address/ (in this case: http://192.168.7.20/ or just http://sharp/) (name resolution for sharp works fine on the network)
I am a bit bewildered by not being able to access the web settings. (primarily I can't change address book entries for email/ftp address, and I can't set the ftp user/pw access credentials without it)
Can I reset this somehow? I've turned the box on/off a number of times and I've changed the copier IP from dhcp to fixed IP and back. (dhcp server hands out 192.168.7.20 either way based on the copier MAC address)
What say the experts?
