E6-14, E7-14 on a MX-753
  • Luthier
    • Apr 2025
    [Error Code] E6-14, E7-14 on a MX-753
    Hey guys. I have a brand new MX-M753N. Throwing codes E7-14, and E6-14 at the same time upon power up. Clear it and it comes right back. Have tried a SCU-PWB, with no luck.
    Anyone else have any experiance with this issue? Next up is the DSPF PWB, but thought I'd ask before ordering!
    Thanks in advance.
    EDIT:
    Both the DSPF, and copy lamps light up via sim 5-3 with no issues. All connectors and such have been checked.
  • mojorolla
    The Wolf
    • 2569
    Re: E6-14, E7-14 on a MX-753
    Could be a bad CCD. Go into SIM 7-1 and execute CCD GAIN FREE or SHADING DISABLE. When the machine reboots, it should keep the error from coming back. See if you can run internal prints from SIM 64-5.
    • copyguy1
      • Jul 2011
      • 142
      We had one brand new out of the box that had the wrong ccd installed in it and had a bad cis in the DSPF. We were told it had ARIES stuff installed.
      • bilyahn
        • Dec 2006
        • 1467
        Have you done a white reference shading adjustment sim 63-2? ROM version should be ICU (MAIN): 04.02.d3.
        Good luck.
        Bil
        • Luthier
          Tried disabling the CCD and shading via the aging, but still comes up with error.
          Tried the DSPF-PWB no luck. Our sharp rep still isn't sure what the problem is either.
          I have done the shading adjustments.
          EDIT: After some more diggin it turns out the wrong boards were installed in the machine from the factory. In the process of getting the correct boards.
