MX7040N - Sharp Error U2-30
  • fbkhan3
    • May 2012
    • 421
    Hope you all doing great!
    Machine throwing this error U2-30 Error,have 2 of these Machines in same building.
    If you kindly point me to the right direction is there anything we should be looking at before interchanging or replacing the Controller or EEPROM?
    And if you could write EEPROM Part Number?
    Regards
  • sharptech
    • May 2011
    • 40
    Re: MX7040N - Sharp Error U2-30
    A U2-30 code means the serial number written on the eeprom of the pcu pwb does not match the serial number written on the eeprom of the mfp pwb. From what I know the only way to get rid of the code is to send both eeproms back to Sharp to figure out which one is corrupt and then replace that one. Sharp will have to put the serial number into the new eeprom. This is assuming you have not been interchanging pwbs between the two machines and just got the pwbs mixed up.
    T.G.G.
    • CorbinDallas
      • Mar 2012
      • 56
      Place a jump drive in the MFP USB Port and execute simulation 56-5. It will download the machine data printout (22-6) in text format. You can then read the data to determine which EEPROM is missing the serial number.
      Sharp Technical Tip TT-082213_1 has full instructions for handling EEPROMs as well as paperwork and instructions of what to send to Sharp to get them re-programmed. Your MFP will be out of commission until you get the EEPROMs back from Sharp, so following the instructions correctly and promptly will get you back up and running with the least amount of delays.
      • fbkhan3
        • May 2012
        • 421
        Thank you so much for prompt feedback...
        This might be stupid to ask but how to get in to simulation Mode with these newer Models cause
        There is no key combination anymore?
        Regard's
        • harleyrider
          • Oct 2011
          • 348
          I am sorry but you need to get and read the manual if you are going to service this and other never models.
          • fbkhan3
            • May 2012
            • 421
            Dear Fella's
            we have received and installed the Controller after Re-Programming the EEPROM from Sharp Germany Both machines are working fine now.
            I would like to Thank and appreciate everyone who contributed in this thread and for guiding me to the right direction.
            THANKS and appreciated.
            Regard's
