Primary Transfer Belt replaced
  • danielcooke
    • Jun 2013
    • 22
    Question.
    I've replaced a belt after it was chewed up into 50 small pieces... now the new belt sounds like it isn't turning.. How can this be checked?? I think that's why the old one is in pieces... and ideas??
  • ZOOTECH
    Senior member of CRS
    • 3378
    Re: Primary Transfer Belt replaced
    Originally posted by danielcooke
    Question.
    Put a small felt tip mark along the edge of belt, see if it moves. The main drive gear is a likely choice if belt doesn't move.
      • 22920
      Do you know what model Sharp? =^..^=
      • danielcooke
        • Jun 2013
        • 22
        MX 2300n purple beast
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2596
          As said, check your primary transfer drive gear. That is usually the primary cause of belts not turning on that series, the alternative is you didn't put starting powder on your belt and you flipped the cleaning blade.
          • austonrush
            Sharp & HP Tech
            • 234
            This can also be caused by worn drums that are not rotating properly (usually a flipped blade in the drum).
            Seen this issue more with the jupiter series then your model but, worth a check.
            • hellcat
              • Jan 2012
              • 123
              Yes on this model be sure to use the proper powder when replacing the belt
              Titanium Hydroxide (UKOG-0321FCZZ) then after running the belt for a few minutes use Strontium Titanate (UKOG-0316FCZZ)
              Is there any copy quality issue? Just wondering why you think your belt may not be working.
