Hello everywon
was called out to a client to setup their MX-3201N machine on their windows 8.1 64 bit system, but for the life of me i can't get the printer driver to load (they had tried several times to do so, i noticed their downloads were dated Nov 2014)
first i tried the installation disk, but the system told me it was an incompatible operating system,,, so i went to the sharp website & downloaded the correct driver for the system, unpacked the zip file & ran SETUP - setup went through the motions & finished stating that the software had been installed, but i couldn't find the printer in "devices & printers"
pings fine,, browser talks to it,,,
so, i tried "add printer", the system found the printer, clicked that, system stated it would load the MX-3201N PCL driver & i clicked OK - about 10% into the installation the system stopped with a warning message as follows:
printer driver cannot be installed
%1 is not a valid Win32 application
so, instead i tried "add a device", the system recognised the machine & installed it, it now appears in the "devices & printers" list, but states "driver not present"(or similar)
uninstalled everything & tried again, same result
tried "add printer" using manual settings, scrolled through the printers list & found the relevant driver, same error message - tried again, this time i clicked on windows update in the add printer dialogue box,, waited,, clicked the driver,, same error message
during one attempt i accidently clicked on the driver for MX-3501FN,, it loaded this driver & the printer seems to operate fine, printing emails, PDF's, pictures etc perfectly - i then installed smartdesk & got fax & scan working fine too, i also installed the printer monitor & this appears to be working fine too
has anyone got any frikken eye-deer why i can't install the MX-2301N driver? and what the heck does that error message mean?
