I've been rather confused in the past about how to adjust the image position for scanning on an MX-4101N, wondering if I can pick your collective brain.
When scanning documents to file, the resulting PDF has a small margin from the edge of the document to the visible image. The leading edge of the image on the document is cut off by a little bit. I'm aware of SIM 50, but not how to use it. I believe that is where I need to start. I mostly need to move the image away from the leading edge and toward the trailing edge, but if there is other information about moving the image towards and away from the front of the machine as well, that would probably be useful.
Thanks in advance!
Thanks in advance!
