toshiba estudio 450 - c010
  • savi0r
    • Sep 2010
    • 363
    [Error Code] toshiba estudio 450 - c010
    Hi guys. I have an toshiba estudio 450 that worked fine the other day and this morning it gave me error code c010. Usually, is it the main motor assy or what else should i check?
  • Luther
    • May 2006
    • 682
    Re: toshiba estudio 450 - c010
    developer unit can cause this error
    • didi2005
      • May 2011
      • 401
      C010 is main motor abnormality, which can be caused by jamming/worn out gears, or main drive problem ~~~
      • fourl6
        • Nov 2008
        • 94
        As above, check for tight fuser or developer units.
        The motor can also wear and become weak.
        If it has a bridge unit you can try removing the bridge unit/finisher, the bridge is driven by the fuser from memory, this creates extra load on the main motor.
        • savi0r
          • Sep 2010
          • 363
          The mag roller on the developer unit can be turned by hand? I want to know how to check the developer unit on this machine. I worked mostly on toshiba's estudio 160 to 233.
          • Riyadh hossain
            If there is no bad sound Just replace main motor
              • 22914
              The last time I worked on this issue it was caused by a seized developing unit. By the time I had returned with the dev unit, it had taken out two the gears in the main drive pack.
              If the developing unit is seizing you'll see piles of developer in the back of the main body, and it will be very difficult to turn by hand.
              Watch for the piles of loose developer. That will be a good clue. =^..^=
              • Harry
                • 228
                Have had this one along time ago risoldered the connector on main motor solved this issue
                good luck harry
