How to get rid of the Call for Service msg
  • MattPhung
    • Apr 2025
    My Toshiba E-Studio 550 gave me a Call for service Message and locked the copier. I can't push any buttons. How do I reset the copier so I can see what's wrong.
  • Sbarro
    • 176
    Any buttons ? Press C and 8 at once and read error code.
    "A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
    What do you despise? By this you are truly known"
    Guess who
    • MattPhung
      Do I have to restart the copier while pressing C and 8?
      • xcopytech
        • Aug 2006
        • 1783
        no, when machine is powered on, just press C and 8 and you will get error code
        • MattPhung
          What does C43 service code mean?
          I pressed C and 8 and the message code I got was C43. Does anyone kow what that means?
          • Baphomet
            Copier Technician
            • Aug 2008
            • 293
            When I get this code I normally just replace the heat roller thermistors and clear the code. You might just need to clean the thermistors. In any case you can clear the code by setting 08 400 to zero.
            • MattPhung
              Baphomet-
              Thanks for the reply. How do you replace the heat roller thermistors? Are there directions online?
              • Baphomet
                Copier Technician
                • Aug 2008
                • 293
                Originally posted by MattPhung
                Baphomet-
                Sorry MattPhung, I could show anyone how to do it, but I could not explain it in the written word very well. However, if you have serviced any fuser in the past it should not be very difficult to figure out by taking your time and paying attention. It is best to remove the fuser from the machine, remove the cleaning web assembly, from there you will be able to see the three thermistors which are all on one harness.
                Good luck.
                • MUMMIM
                  • Jan 2008
                  • 125
                  i think ! the fist you can try pressed 0 and 8 when you tune on the machine
                  press 400 - star
                  press 0 - set
                  restart the machine
                  fun
                  if it don't run, call service
                  fun again
