PDF Direct Print.
  • seansbar
    • Dec 2010
    • 198
    PDF Direct Print.
    Does the eBN copier series support PDF Direct print?
    PDF direct printing is a feature implemented in printer firmware. It allows Adobe Acrobat (PDF) files to be sent straight to the printer, without printing via an application or using a printer driver. This may be useful in situations such as proofing PDF files before sending to a printing bureau, or batch printing a large number of PDF files, (for example via a command-line script).
    Sure does. Put PDF on a USB flash drive, put in USB port on an eBN. Press [Print] on the Home screen on the touch panel. Select [USB] from the drop down menu. Select proper file and settings and hit [Print].
    New post cause the word print cannot be the last word of the post title, if you expect any replies.
  • clint@clintsimonsen.com
    • 120
    Re: PDF Direct Print.
    I dont believe so. If you are thinking the same way as a Kyocera does. It was never on the road map. However as it can direct raw print and can read pdfs' there is no harm in trying it.
    Sent from my F8331 using Tapatalk
