Toshiba 2040c F109-4 Firmware?
  • gideon
    • 283
    When I run 3+C +power - 5 I get
    SRAM License Status: Key Mismatch
    FROM License Status: key Mismatch
    I guess that I need to install the firmware, does anyone have the firmware?
    If you have any other idea please let me know.
    • 22914
    Re: Toshiba 2040c F109-4 Firmware?
    I'm thinking that you'll need more than that. I suspect that you've got a dead SRAM. When you replace the SRAM you'll want to copy data from FROM to SRAM to correct the mismatches. Then firmware. =^..^=
    • gideon
      • 283
      This problem had been fixed, I just had to restore the 1,3,and 5.
      Thanks to all.
