Toshiba estudio 2508a light copy problem??
  • Arbad technology
    • Apr 2025
    Hi, can anybody help me solving the issue that toshiba estudio 2508a having very light or poor copy.
    • 22920
    Re: Toshiba estudio 2508a light copy problem??
    What have you done so far? =^..^=
    • Edward
      • May 2019
      • 32
      Clean optics then do gamma calibration in user mode or admin. Make sure no generic toner.
      • Zastawa
        • May 2019
        • 25
        I Like Edward's reply. You can also check developer unit. Old developer? Replace. Check primary charger assembly. Clean the grid.
          • 8071
          How many clicks are on the copier?
          • Ray.lb
            • Mar 2019
            • 14
            I have the same issue with an ES 3508A
            The image (copy or printout) gradually became abnormally Light but when i access the toner density check under Adress 2000 in service mode the density meter shows 230% but in result the image is two light. I think i have a toner density sensor issue.
            Can anybody tell me how to reset this sensors settings and or decrease the sensor sensitivity to increase the Toner density in the developper assembly ...
            Thanknyou Guys.
              • 22801
              Thanknyou Guys.
              thanks for posting a problem to a totally different machine in a thread where the OP hasn't returned to tell us of the fix over a year later.
                lol
                • Ray.lb
                  • Mar 2019
                  • 14
                  Phil B
                  The ES 2508 and 3508 share the same body with different speeds they use same components and faces similar problems i guess...
                    • 22920
                    Just basics:
                    Clean optics.
                    Wand the slit glasses.
                    Perform a calibration.
                    And if you want a serious reply I'll need an image to look at. =^..^=
