Toshiba e-Studio 2500AC - Humming noise
  • Stonewall
    • Apr 2025
    [Misc] Toshiba e-Studio 2500AC - Humming noise
    We have two e-Studio 2500AC MFPs.
    Both have issues.
    The one in our front office began to make a constant humming noise coming from the front right side of the unit.
    (picture attached - arrow indicating the source area of the sound)
    Anyone have an idea about this?
    Unfortunately, I am having a hard time finding a qualified Toshiba service tech***
  • Claudio_Napoli
    Toshiba Copiers Technical
    • Jun 2020
    • 27
    Re: Toshiba e-Studio 2500AC - Humming noise
    yes it is the noisy fan, just take it apart and put a drop of oil on the motor shaft
      • 22916
      I'm going to take a guess that you've got a fan F3 vibrating. If you press on the cover right there, you can damp the vibration. It's located right here:
      Under the cover it looks like this:
      The vibration is annoying, but does no real harm (except perhaps to your sanity).
      Is that it?
      • Rusty.Harris
        • Jan 2021
        • 605
        When customers would call me for a noise, I would tell them to turn on a radio loud enough to drown out the noise.
        TSB-1815 I think only applies to the 5005AC series, but might be worth a try if is the same issue.
        • Vincent128
          • Sep 2015
          • 341
          The better fan in the TSB has solved this issue - i lubed a few but the noise would return. So far all the ones i have install the new fan in have stayed quiet.
