e-studio 2508a
  • bruce 49dcs
    • Jan 2017
    • 140
    e-studio 2508a
    lucky me i sold a 2508 last week and today i was called to fix it the machine wont start no screen energy save is blinking and i have some green lights on the system board and colling fan is on but then i hear what sounds like a relay click and it goes dead and tries to start again fuses on power supply check good
    ive had hard drives on diff models go bad but then i at least had a screen or an f code
    what do you all think
    thanks
    bruce
  • gliderider
    • May 2015
    • 131
    Re: e-studio 2508a
    Had the same issue and same symptoms on that model last year. I tried numerous things without success. Called Toshiba tech support and they had us replacing the sys board. Appeared to work but within a month the problem was back. This time I checked the line voltage at the wall and it was within spec. Even installed a line filter. Failed again. Went through the usual suspects. Reseat memory, change and HDD and reinstall latest firmware at that time. Copier would start working, then within a few days the same problem would reoccur. Finally brought copier into office and did a deep dive on it. Could not get it to fail. Brought back to customer and within a week the same symptoms were back. Started to believe that the problem had to be the location, but could not prove why. Toshiba could not seem to offer a solution either. Maybe by now Toshiba tech support might be able to shed more light on the problem.
    • bruce 49dcs
      • Jan 2017
      • 140
      Re: e-studio 2508a
      did you replace the machine for the customer and if so is that one working
      • mojorolla
        The Wolf
        • 2569
        Re: e-studio 2508a
        Check for DC voltage coming out of the the power supply.
        Had one earlier this year with the same described symptoms.
        • Rusty.Harris
          • Jan 2021
          • 605
          Re: e-studio 2508a
          Try replacing the memory on the system board. On various other TABS machines, I've seen some whack-a-doodle problems
          solved by replacing the memory card.
          • gliderider
            • May 2015
            • 131
            Re: e-studio 2508a
            We tried replacing the memory early in the troubleshooting process but to no avail. Also replaced the power supply which also made no difference. I do not know if the front office ever tried getting the copier replaced.
              • 8060
              Re: e-studio 2508a
              Was the copier new when it was installed? The e2508A is a discontinued model.
              If not new/ did the copier come from your inventory or was it purchased from a used equipment reseller?
              I would install a Tripp Lite LC1800 line conditioner. If the Tripp Lite makes a lot of clicking noises the building has dirty power and they need to buy the Tripp Lite. Solves all kinds of weird power problems.
              I have been using Tripp Lite line conditioners for over 15 years to good effect.
                • 22801
                Re: e-studio 2508a
                I would install a Tripp Lite LC1800 line conditioner. If the Tripp Lite makes a lot of clicking noises the building has dirty power and they need to buy the Tripp Lite. Solves all kinds of power problems.
                tripp lite is cheap crap...
                look into ESP they have a good warranty depending on the model.
                ESP Multi-Stage Surge Protection and Power Conditioners
                • bruce 49dcs
                  • Jan 2017
                  • 140
                  Re: e-studio 2508a
                  thanks for all the input im replacing the machine and when i get the bad one in the shop and fix it ill post what i did
                    • 8060
                    Re: e-studio 2508a
                    If the replacement copier starts acting wonky, you know the problem is unstable power from the power supply.
                    Toshiba's like and need a clean, stable. electrical supply.
                    We have had power lines hanging from poles swinging in the wind with a bad connection at the pole to the customer's building causing new copiers to go wonky.
                    I have a copier customer their main job is repairing power lines in Florida due to all of the high wind effects that occur in the state.
                    • Copiertech 1452
                      • May 2021
                      • 4
                      Re: e-studio 2508a
                      Dear install the firmware new version.
                      Yes I have TOSHIBA e studio 2508a firmware for sale Pak Rupees.
                      Please contact my whatsapp number.
                      +92-3224868144) (Pakistan Lahore)
                        • 22801
                        Re: e-studio 2508a
                        violation of forum rules.... take this discussion to PM
                        Discussion of illegal activities such as software and music piracy and other intellectual property violations are not allowed.
                        • tnrtt
                          • 150
                          Re: e-studio 2508a
                          Yes, I think you'll be bounced shortly, A-hole.
                            • 22801
                            Re: e-studio 2508a
                            Hopefully you reported him to admin.
                            • bruce 49dcs
                              • Jan 2017
                              • 140
                              Re: e-studio 2508a
                              I have no idea who this guy talking about firmware is
                              I did not ask him or anyone else for firmware
                              i have no control over who posts
