E-studio 264CS Admin password
  • Fabien694
    • Nov 2022
    • 4
    Hello everyone. I have just bought a second-hand E-studio 264CS to replace my 2550C which remains with error C970. I would like to reset it in particular to configure the IP address. Unfortunately, I don't have the administrator password. I tried 123456, 0000 etc... Nothing works. Could someone help me? A big thanks to all of you.
    Fab.
    • 8066
    Re: E-studio 264CS Admin password
    This copier is a very old relabelled Okidata. Toshiba Tec no longer supports this model and does not even publish a service manual on it.
    You made a really bad purchase decision.
    Try 999999 .
    • Fabien694
      • Nov 2022
      • 4
      Thank you, I just tested but this password does not work. This device is intended to help me while waiting to find the problem on my other device. An E-studio 2550C. Error F101 solved but C970 that comes and goes. I don't lose hope. Thank you again.
      • jonwill
        • Jan 2017
        • 9
        Fab.
        Try, aaaaaa
        • Fabien694
          • Nov 2022
          • 4
          Hello, I just tried aaaaaa but unfortunately it doesn't work. Thank you again.
          • jonwill
            • Jan 2017
            • 9
            Service menu
            When the equipment is in standby mode, access the password entry screen by pressing [Setting] → [#] → [0] → [1] → [0] → [3] → [*].
            Reset Admin
            Password Execute Returns the administrator password to the factory default value.
            Note! The initial Password is set to "000000" (six zeros).
            • Fabien694
              • Nov 2022
              • 4
              Good evening. Thank you. I tested the procedure. There are some differences but everything worked. It's great. I was able to reset the administrator password. Once reset, the password is "aaaaaa". Thank you again. I can now set the desired network settings.
              • sappa12
                • Sep 2023
                • 55
                C970 looks like a bad terminal on one of the main charges
                im glad we rid all of e-264/263 models
