Toshiba e-studio 352 developer setup?
  • haydar64
    How can i set developer at this machine?
    copies are ligt and worn.
    any auto developer adjustment is avalaible?
    how can i do it?
    Best Regards.
    HAYDAR64
  • Harry
    • 228
    developer
    shut down copier, hold 0 5 keys power up copier with keys hold adjust appairs in the display digit 200 then start after a 3 or 4 minits display change to ajust mode if the range is 240 everithing is ok set and turn of the copier.hope that help
    • blaineV
      • May 2009
      • 14
      I assume you cleaned and checked charge/trans/sep wires make sure they are clean...
      • haydar64
        Yes, i was cleaned all wires and rollers. Developer and toner is changed but copy is not good.
        • Peter Sim
          • Sep 2008
          • 445
          Hai, is this machine are same adjustment with the e-studio450?Need to wait for 3 to 4 minutes to complete the developer adjust? I dont have the adjustmet code for e-studio450 machine.
          • ivovb
            • 695
            Yes Peter,
            they are the same concerning developer adjustment.
            BR
            I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
            • Harry
              • 228
              Hi Haydar
              You have to print out a List At Machine of Reboot with 04 111 e set.
              If quality is good check The optiks dirty optiks make fade and clear copys.
              Good luck
              • blaineV
                • May 2009
                • 14
                Take the glass off and clean bulb mirrors and underside of glass, also clean glass of laser unit.
