E-Studio 450 E-020 jams
  • pioneer007
    • Oct 2009
    • 37
    Multi copy runs I get jams with the E-020 error.
    Paper exits fuser, partialy enters the bridge unit and jams.
    Makes a strange noise when it does this. Paper hits nothing.
    Its like the paper is being pulled into the bridge unit but has not been fully
    released by the delivery into the bridge. Paper is clear of the fuser.
    Seems like a sensor/timing issue.
    You find two pieces of paper over lapped. The one entering the bridge
    unit that jammed and the other comming up threw the fuser unit.
    anyone?
  • toshibadale
    • Apr 2007
    • 117
    Check the exit sensor. It can stick. I've seen them swell up causing it to stick causing this problem.
    • pioneer007
      • Oct 2009
      • 37
      Exit sensor as it leaves the fuser? The one mounted on the door?
      We have very few Toshibas left in the field as were Canon, Sharp and HP dealers. These are remnents of a previous aquisition. You may have to identify where the sensor is located. If you would please.
      • Harry
        • 228
        Yes Sir it is in the Door right up on de Fuser Exit.This thing swells up from Fuser heat and cause ths Problem.Another is the Exit Motor the motor drive move the Exit Rollers failt and that spell the noise when jamming swep the motor and try another one.
        Thats all
        Good Luck
        • pioneer007
          • Oct 2009
          • 37
          Excellent my friend, and thank you!
          • the Copy Doctor
            • Jul 2008
            • 3
            I have seen this on the e-Studio45 but only when duplexing, the solenoid on the bridge unit that diverts the 1st side down partially into the lower tray sticks causing the paper to enter the bridge where it stops and the next sheet runs into it in the fuser.
            Just clean the solenoid plunger and may have to remove or replace the "cushion" on the plunger.
              • 22917
              Re: E-Studio 450 E-020 jams
              I've got a eS453 with these symptoms. E020 and E910 jams. If I remove the finisher and bridge, it's E020, and the exit roller stalls and makes the noise. Here's the list of new parts:
              Exit roller
              Exit idlers
              Exit bushings
              Exit sensor
              1/2 addition wrap on the return spring
              Two new exit motors with harness
              Usually it's the exit sensor or motor that solves this issue.
              As a desperation measure I've ordered up the logic board.
              Perhaps the voltages are sagging on the power supply?
              What have I missed? =^..^=
                • 22917
                The logic board and power supply did not help. My customer is getting a loaner. I also pinned out the wiring from the motor to the logic board. I suppose there is a remote possibility that there is a 24 load dragging down the 24vdc at the motor, but I was monitoring the 24vdc at the power supply and it stays solidly at 24.9vdc before, during, and after the motor stalls. I'm going to find a dark corner to shove this old POS.
                Did I miss anything obvious? =^..^=
                • didi2005
                  • May 2011
                  • 401
                  Exit roller
                  Exit idlers
                  Exit bushings
                  Exit sensor
                  Check also the 2 metal shafts that hold the small exit rollers where it will get sticky thus affecting the exit roller...Usually I clean it with thinner~~~
                    • 22917
                    Exit roller
                    Exit idlers
                    Exit bushings
                    Exit sensor
                    Thanks for considering my issue. Those idlers are shafts are new. =^..^=
