my e-studio 120 just refuses to copy. just an alternating flashing of the Letter L and number 1.
e-studio 120 alternate flashing L and 1
L1
Yes it's a problem with the scanner carriage. Probably, as mentioned, the scanner lock. I usually break the lock out so it doesn't get turned back by accident. I have also seen the scanner not able to move in it's high speed mode (when it moves over to the ADF glass) because the rail needed to be oiled. A lot of times this also contributes to a noise when the scanner moves back home.I will not give you service manuals or firmware.Comment
Guest
L1
Yep.Comment
Try cleaning and lubing the scanner rail. If that doesn't work, I would replace the scanner motor. I've had to replace several of them.Comment
