toshiba e studio fax forwarding cont...
  • digicor
    • Jul 2008
    • 1141
    I have been able to smb to the fax folder, and have top access turnd on and pointed to the fax folder, yet no fax in the folder? do i need more software to run this app? i have tried from a 281,351 and no such luck. yet i still have the all the possible features for this enabled, and the fax does print and recieve as normal.
    any help would be great
    thank you
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    The steps are:
    open topaccess
    go to administration
    login
    go to registration
    click fax received forward
    when the screen changes select fax forward and save as file buttons
    select on error from the print option
    click pdf on the format and make sure mfp is destination and I leave the file name as default so I can see when it came in.
    then logout
    and reboot the machine (not necessary but I like to do it when I make changes to insure they are applied).
    try it and see if it works.
    • digicor
      • Jul 2008
      • 1141
      OK ILL TRY IT
