PCL XL error on when printing to Toshiba copier
  • jjw23
    • Sep 2008
    • 36
    I am getting the following error when printing to Toshiba estudio 5520c
    PCL XL error
    subsystem: xlparse
    error: illegalattributedatatype
    operator: parser
    position: 118416
    This error only comes up on one user and it is intermintant.
  • ivovb
    • 695
    Does this user has the same OS like other ones? Does this happens when printing specific files like pdf? ...
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • jjw23
      • Sep 2008
      • 36
      yes its the same as other have, we run windows 7 and xp here. happens when printing any type of file.
      • Chip Resets SA
        • Sep 2010
        • 46
        Have you loaded the PCL driver or PS driver? It could be a driver issue?
        • mrwho
          Major Asshole!
          • 4299
          I'm no toshiba tech, and rarely do I fiddle with them, but if it has a PCL XL error, the driver is most likely PCL6.
          First I'd completely remove the driver (not just erase the printer on the printers folder, but also remove all the files on the printer's server properties) and reinstall it again.
          Secondly, if the machine supports PCL5c, I'd try that instead - I favour it over PCL6 because the spools are smaller, usually prints faster and, being older, it's much more tested and proven. Also, I think PCL6 doesn't offer any tangible benefict over PCL5c. I know, it's somewhat of a personal taste, but I think I'm not the only one here with this opinion.
          Mascan42
          Ibid
          • jjw23
            • Sep 2008
            • 36
            its the same driver that everyone else uses, its a shared copier on the network.
            • mrwho
              Major Asshole!
              • 4299
              Even so, since that problem ocurrs only on that computer, you mustn't think of it as a "computer like the other computers", since it has some problem that no other computer has. So you need to forget about the other computers and treat that one separately.
              There are a number of things that could make that computer different from the rest: windows updates, software installed, drivers installed, driver versions, even malware that could have been on that computer in the past but never on the others could be a cause for that.
              So you must put aside those preconceptions and troubleshoot it from the beginning. Ultimately you might need to reinstall the entire OS to solve it - and even that could not work, if we're talking about an hardware problem - corrupt RAM can cause a great many things, just to give you an example.
              Mascan42
              Ibid
              • tinnyjay
                • Oct 2009
                • 654
                PCL XL error
                subsystem: xlparse
                operator: parser
                position: 118416
                I'd suggest to use a different version of driver.
                "Who loves the roses,must also bear thumbs"
                • ToshibaTech
                  • Apr 2007
                  • 580
                  You should use the PS driver on the 5520c mainly because it is the only driver that supports 1200dpi for this machine, and generally I have less issues using a PS driver than PCL on anything. Select 1200dpi under the Image tab and then click Settings at the bottom.
                  I will not give you service manuals or firmware.
                  • jjw23
                    • Sep 2008
                    • 36
                    I have tried reinstalling the driver, and it does not fix the problem. Only seems to happen the most when printing color from solidworks.
                    • ToshibaTech
                      • Apr 2007
                      • 580
                      Sounds like you've narrowed it down to specific program or at least (i looked at the OP again) a single computer. Not sure that much can be done except to explorer the offending program's options to see if there are any dealing with printing, RIPing, etc... Maybe a way to print as a raster image instead of print commands like in Adobe Reader. Good luck!
