Basic network setup for TOSHIBA e-STUDIO
  • jamesbondlee
    Hello!
    everyone.......
    i'm interesting & learn in basic how to do a network setup for TOSHIBA e-STUDIO.....
    Any input will be really appreciated
  • copyguy5
    Toshiba Estudio Printer Setup
    Toshiba use a number of different Print Controllers, depending on the Copier Model and Series. Generally you can tell from the Test Sheet Setting List printout.
    Let me know. I can probably give you the Setup Instructions.
    COPYGUY5
    • jamesbondlee
      That for the 352
      • mnrland
        can anyone assist me with a estudio 450 set up to print over the network, I have the gm-2010 enabler, but for the life of me can't get this thing to print, i can ping it show ok, it shows connected in the topaccess docmon. everything on my network looks good , am i missing something , i just added the gm2010, is there more to setup than just pluging in?
        Mike
        • ToshibaTech
          • Apr 2007
          • 580
          easiest way to set one up IMO is:
          1. do what you have done
          2. user functions > admin > 123456 > network > SMB
          3. change name from mfp-xxxxxxx to something nice like "toshiba"
          4. on computer go Start > Run
          5. type \\toshiba (or whatever name you gave it)
          6. double click on PS or PCL driver (computer will pull driver over takes 1-5 mins usually)
          7. right click file_share and add a short cut
          you can now print to the device and access scan to file documents via the shortcut you made. no need to set a static ip or change dhcp settings.
          I will not give you service manuals or firmware.
          • grafix
            • Mar 2010
            • 18
            ToshibaTech
            Yes!!! Thanks!
            • Rodoz
              running 3511 & 351 on the same domain /network
              I have one 351 estudio and one 3511 on the same domain and network. I read Jamesbondlee's request and the response and tried the solution on the 3511. I have a response ok Can both of these machine co exist ok on the same network using the SMB naming technique suggested to Jamesbondlee by grafix Toshibatech ? ?
              • Mr Spock
                Vulcan Inventor of Death
                • Aug 2006
                • 2064
                They can but the name needs to be different.
                • b1406
                  • May 2008
                  • 51
                  hello
                  can any one help me how to setup scanning on toshiba estudio 4511
                  I ha the copier connected to network i can print with it but can not scan
                  I would like to use it with toshiba estudio file down loader but I can find the soft for it
                  thanks
                  • wolferin0
                    Hi.
                    For network scan with eStudio 182, i need something else then GA 1191?
                    Only the printer appears on the network.
                    Some guys say I need GA 1201 and GJ 1160 for the network scann.
                    For the moment i use the machine only like a printer, by installing Toshiba Utilities.
                    How can settup scanner? And what software i need for scanner?
                    Thanks.
                    • vellankis0415
                      Re: Basic network setup for TOSHIBA e-STUDIO
                      Tried the below but didn't work for Toshiba 351C, While i am able to access the same from IE. Also interestingly PS3 interrupts and exists without installing the drivers.
                      FYI... I have 3510C drivers also installed on the same machine.
