Hi all. I have an issue with these machines. I have to print A3 land maps. But when the print is out, it' darker, in some cases A LOT darker than the original. It's like the original, but with way darker contrast. There are a few things that need to be mentioned here:
-these copiers only work with compatible toner (Katun)
- the drum is Katun brand, and the developer in these machines is way over 80k, 90k.
So, my questions are :
1. How can i "light up" the print? Can it be done from the machine ( 05 or 08 adjustments)? Or can it be done from the PC ( toner save ON from printing preferences)?
2. Is this because of the developer? If i change it, would the copy match exactly the original?
3. I have machines with the same number of copies, same drum, same life span developer and they work great. So, what is different in those machines from wich i get the dark copy...????
THanks and any sugesstions are welcome.
