serial number
  • jawir
    • Aug 2007
    • 107
    serial number
    Hi Pro,
    Does any one know how to check and see serial number machine eS163/166/203/206 if the label out side on the machine already gone/broken.
    thank you and regards
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Most toshiba's have a label on the back cover and one on the inside front frame member. Also printing the internal function page will print the serial number.
    Try 9 and [start] while powering on then 101 [start] and see if it is on the page at the top...
    • jawir
      • Aug 2007
      • 107
      Dear Sir,
      Yes, before I did try, but the serial number is not in there. but if I try in eStudio165/205 the serial number printed on the top of the function list.
      also in eS165/205 we can check by using 08-995. but is not working in eS163/203. please if there any other suggestion.
      regards
      • elcondor
        yes you are right
        • tech1224
          you have set off the copywright erroe have you by switching out more than one board at a time have you. Sometimes if you aren't careful you can do it before you know it.
          • nhatthuc0000
            • Dec 2007
            • 44
            i think that you can change serial number and enter one new.
            Good luck to you!
            • jawir
              • Aug 2007
              • 107
              Hi all,
              thank you, for all of your suggestion.
