ReRite 8 seems quite a bit different than ReRite 6.2.0.44.
I realize RR8 is now more of a web based product and uses Abby as an OCR engine replacing Nuance. I realize Toshiba bought ReRite from Redmap, so Redmap is now out of the picture.
1). Is there no longer a rotating ball on the Task Bar of your PC to let you know ReRite is processing a file?
2). In the Inpath, where is a .cfg file written?
3). Will a RR8 license work in for RR6.2? I know a RR6.2 license will not work for RR8.
4). Is Wordperfect and eBook Reader conversion no longer available?
5). Do you have to manually create an OutPath when scan to folder?
6). Does RR8 require any kind of server restart?
Thanks,
Thanks,
