Toshiba e-Studio 4520C fax problem. Communication error
  • checkgio
    Hi everyone, I found this forum while searching for a solution to a fax problem I'm having. Users at the office keep getting intermitent Communications Error on our Toshiba MFP's. Problem is that every time I've tested the machines to see if there is anything wrong, my faxes go through fine even if it's to the same number that was receiving an error. I was wondering if anyone knows what the following codes mean on the Transmission journal. The following are 2 entries from the journal, which are the status codes that I see repeating.
    Mode G3 401 Status NG 00D2
    Mode blank Status NG 00B0
    Any help would be greatly appreciate.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Toshiba e-Studio 4520C fax problem. Communication error
    00D2 Poor image quality Quality of the received image is poor. Retry the transmission.
    00B0 Initial signal not detected NSF/DIS cannot be detected. Check the receiver and attempt
    the transmission again.
    Check if it is a dsl line and if so if they have a filter installed.
    Turn the attenuation up for both send and receive.
    • TheOwl
      • Nov 2008
      • 1733
      Assuming there is no DSL signal accross your fax line, try switching from a 2 pair phone cable to a 1 pair phone cable. This will help to eliminate mode 3 wiring faults.
      After that, try turning off JBIG Compression and if there is still an issue, turn off v34.
