TOSHIBA eStudio 166
  • jrbangsaja77
    • Sep 2012
    • 10
    TOSHIBA eStudio 166
    Hye to everyone, i am new in photocopy technician, i just want to ask what is reset code for Toshiba e-Studio 166. I just service & replace the Drum, Cleaning Blade & Developer, but still the Service Lamp is ON, not blinking no any error but the light is ON, my question is how to make reset or switch off the Service Lamp to make it normal. Machine is normal working fine.
    Thanks & best regards,
    Juljie Bangsaja
  • bojans
    • 1313
    Re: TOSHIBA eStudio 166
    Reset 08-252 to 0
    But after replacing those parts you should first initialize developer.(Adjustment of Auto-toner sensor) 05-200
    • jrbangsaja77
      • Sep 2012
      • 10
      Thank you very much for your information, yes sir i already calibrating the developer 05-200 but i have doubt while running the calibration how i know it is done machine automatic stopped by itself or i manually switch off after reading the calibration, means the light of developer will be done or turn off by itself then we will turn off the machine?
      • savi0r
        • Sep 2010
        • 363
        It doesn't exactly go this way.
        1. you start the machine with 0 and 5 pressed and enter 280 and then press start. The main motor starts rotating.After it stops...
        2. You remove the developer unit. Empty the old developer. Vacuum the developer station ( if it has any foreign objects, it will leave blank spots on the magnetic roller).
        3. Replace developer D-2320. As you pure the new developer in the station, rotate manually the magnetic roller to see how the developer layer is forming on the magnetic roller.
        4. Put back the developer unit in the machine, and without the toner cartridge, you enter 200 and press start ( auto-toner sensor).
        5. The auto-toner sensor adjustment stops itself and shows values between 236-244 (aprox). You press start and then intrrerupt.
        6. As Bojans said, you turn off the maintenance led by powering the machine with 0 and 5 pressed and enter 252, then 0 then start and then intrrerupt. My suggestion is to specify a value for 05 ->251. This sets the maintenance led to turn on after a specified number of copies. It's easier to track the life of the developer or the drum.
        Good luck !
        • JustManuals
          • Jan 2006
          • 9865
          Paul@justmanuals.com
          • jrbangsaja77
            • Sep 2012
            • 10
            I am very happy, thank you very much for your support, Borjan & Saviour <-- very nice explanation thank you so much my job will done & successful. Once's again thanks a lot & best regards to all...
            • savi0r
              • Sep 2010
              • 363
              Glad we could help. Best of wishes!
              • bojans
                • 1313
                You're welcome.
                • salahaddin
                  • Jan 2015
                  • 4
                  I have that problem, service call lamp is on, i want to off that, how can I make that?i dont nothing to do that copier.when i saw that the service call lamp is on.
                  • sdrawkcab
                    Confused & Bewildered
                    • Jun 2009
                    • 317
                    I'm typing this slowly so hopefully you'll understand.........READ THE POSTS
                    Some days, it's just not worth chewing through the restraints
                    • salahaddin
                      • Jan 2015
                      • 4
                      Hi
                      I have a problem with toshiba 166. When i turn on it 0 is blinking and continue 0 blinking.i change the developer and everything i can to do with it but the problem is remain please help.
                      • Harry
                        • 228
                        switch off power hold 1 3 * turn copier on and wait with this Keys hold then the copier inizializate thats all try this. for maintenance lamp i think it is 08-251 000000 and interrupt. reguards Harry
                        • buuluu
                          • Apr 2014
                          • 49
                          Juljie Bangsaja
                          You power off and press & hold down # 13 power on wait for a few second release and power off/on.
                          • salahaddin
                            • Jan 2015
                            • 4
                            Originally posted by salahaddin
                            Hi
                            I did, but the problem is remain...
                            • savi0r
                              • Sep 2010
                              • 363
                              You tried *+1+3 and it doesn't get in to ready state?
