Good morning,
I've just had an issue with my e-Studio 230, after trying to scan the touch screen became unresponsive, turned the machine off at switch but now it will not go past the boot screen.
- Upon turn on, it now does not get past the grayscale image of the copier on the touch screen
- I heard a clicking from the HDD
- I've removed the HDD and tried to mount on PC, it says it is unreadable and there is loud clicking from the drive (WD400 40GB), a usual sign of HDD failure to me
- I've tried to start copier without the HDD but same problem
If somebody could advise how I might be able to rectify this problem that would be fantastic.
Thanks,
Sam
edit:
I've replaced the drive with a spare 20GB I had about, it now gets past the screen I described above, but then it goes to call for service.
How would I format this drive for use, as I assume that is now the problem - do I need the firmware?
Thanks,
Sam
edit:
