Toshiba E-Studio 255 Hard Drive Replacement
  • CNG
    • Apr 2025
    Hello All,
    I require some assistance with replacing a hard drive on a E-studio 255. Firstly will a 320gb SATA I drive work in this machine or will that be too large? The machine was supplied without a hard drive so I think I will require the firmware to be installed again.
    Can someone assist me with the procedures required to replace the hard drive, and also from where to source the firmware from (Justmanuals.com? open to suggestions) I am willing to pay to play (within reason). The other thing is that I am from Australia and am unsure if this affects what firmware I have to install.
    Thank you in advance for your assistance.
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: Toshiba E-Studio 255 Hard Drive Replacement
    The machine should have a hard drive attached to the system board, and paul (just manuals should have the latest firmware) as most people on this site i do not give out firmware. They were originally shipped with 60GB hard drives but we have put 120gb plus in them with no problems.
    Why are you replacing the hard drive?
    It didn't say that I couldn't do it in the manual.
    • CNG
      Thank you michaelc for your reply.
      The machine was purchased at auction and was ex-govt. I can only suspect that they removed the drive for security purposes?
      I will get in touch with justmanuals and make the necessary enquiries about the firmware.
      Are you able to assist with the procedure to install the firmware once I obtain it from justmanuals?
      Finally I am after a GD1250 Fax Kit. Would anyone have any leads as to where I could find one?
      Thank you for your help, its greatly appreciated.
      • michaelc
        Field Tech
        • Mar 2011
        • 590
        Justmanuals might give you the walk through procedure with the firmware, i am not sure though. If not post back here and i will help you.
        • CNG
          Thank you for your offer of further assistance.
          I have been researching into the GD-1250 fax kit and was wondering if there are any differences between the kits from differing regions (e.g NA/TW, EU/AU/AS, C, J). I can only find the GD-1250 kit from North America. Also is the GD-1250 universal in shape as it appears to fit many different e-studio models? Currently my machine has the USB + Network connections and a blanking plate for what would be the telephone connector. Any e-bridge 3 GD-1250 will fit?
          Thank you for persisting with my questions.
          • hoanphuc20033
            • Mar 2011
            • 38
            if you need it sent to your hdd firmware up okay
            contact:
            MOVING SERVICE COMPANY LTD Emerald Buddha
            Address: 202 Tran Hung Dao Q1 TP HCM VIỆT NAM
            Expert: sales, leasing, salamanders provide copier parts warehouse.
            Tour: board repair resource, sys board, main board, board scan ...
            Expert: purchase, exchange, used copiers.
            Tel: (08) 54041727 - 0938877144-0976583422 Mr. NGHIỆP
            YM: tienphatngoc2011@yahoo.com / hoanphuc20033@yahoo.com
            GM: vannghiep25@gmail.com
            Westie: mayphotocopytienphatngoc.blogspot.com
            • Acme
              • Jan 2013
              • 155
              Check you P.M regarding the fax unit.
              • MUMMIM
                • Jan 2008
                • 125
                Hi Nghiep!
                Can you share to me that firmware (e255), i am needing it. send to me via email: thientinhvnn@gmail.com
                thank you very much. i shall go to sg and invite you coffe
                MUMMIM
                contact:
                • vinhsesco
                  • Jun 2009
                  • 30
                  Originally posted by MUMMIM
                  Hi Nghiep!
                  MUMMIM
                  firmware huge amount can not be sent via email so you can bring up the copy usb. if not I can send original toshiba dvd for you.
                  • nhimlongxu
                    You need to install software, fix the line copier toshiba contact me.
                    • hoanphuc20033
                      • Mar 2011
                      • 38
                      you come to sg
                      we change it
                      • MUMMIM
                        • Jan 2008
                        • 125
                        Thanks for reply to help me, can you give me your address and your phone, maybe i shall go to saigon meet you next week.
                        Mummim
                        • hoanphuc20033
                          • Mar 2011
                          • 38
                          202 trần hưng đạo q1 tp hcm
                          dt 0938877144
                          • andiboyshqipo
                            Hello, I did the firmware upgrade after hdd replacement and the firmware was T470ALLA068USB. It works only as a photocopier now, the scanner and printer functions do not work, and it has error 4030. I read that it may be a dongle problem, but I didn't change any other hardware. Can anyone send or share any other firmware for toshiba e studio 255?
