I have a copier toshiba e-studio452. When I command 20 copy, after finishing 11 or 12 copy by showing "wait" machine rotate for a long time about 10 minute. this is happened from all drawer and bypass,Now what can I do? please help me any one,I will pleased.
toshiba e studio 452 showing "wait" during copying
Tags: None
Re: toshiba e studio 452 showing "wait" during copying
try to reformat the hdd 952 I be leave -
08-690 Format the HDD. Then do a 08-1119 to clear the RAM.
The users have probably been improperly turning the copier on/off via the hard switch which has caused the HDD to become corrupted. The users need to use the proper shut down sequence from the LCD to gently power down the copier.
You should update the firmware to V355 while you are there.Comment
[QUOTE=didi2005;410839]Sounds like fuser error, not enough heat...[/QUOTE
If the fuser lost heat it would code outComment
Riyadh hossain
[QUOTE=stockman123;410872]Is thermistor responsible for that? problem is "please wait" after 10 or 11 copy , it occur frequentlyComment
Bad thermistors will cause those symptoms. I've replaced several on e350 series and e281c series because of that exact problem.Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?Comment
Riyadh hossain
Finally I solved this problem .One thing is very regret that here are a lot of expert, they could not solved my problem. It occurs for low voltage When I changed the power source, my copier is ok.Some expert said some setting such as 08>952,1119, I can't enter this settings,Why????????????????????Comment
Finally I solved this problem .One thing is very regret that here are a lot of expert, they could not solved my problem. It occurs for low voltage When I changed the power source, my copier is ok.Some expert said some setting such as 08>952,1119, I can't enter this settings,Why????????????????????Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?Comment
