TOSHIBA e-studio 4555C - TOSHIBA Universal Driver
  • vmendoza03
    • Jun 2014
    • 16
    [Misc] TOSHIBA e-studio 4555C - TOSHIBA Universal Driver
    hi Guys,
    I have an e-studio 4555C printer on a server for network print. I used the driver: TOSHIBA Universal Printer 2. It is very slow when we print. It takes 20 seconds to print an all-text, single-paged word document. It also shows a "not responding" printing dialog box before it finishes. I have already disabled SNMP on the printer properties.
    Do you guys have any idea on how to make it faster? Is there a setting that we need to tweak?
    Thanks in advance!
    • 22914
    Re: TOSHIBA e-studio 4555C - TOSHIBA Universal Driver
    Typical of universal drivers, The driver has to interact with the machine with every print job. I would recommend just selecting a PCL or PostScript print driver. Both will be faster than the universal, and have more features. Personally I lean towards PCL drivers in most situations. PostScript in graphic situations. =^..^=
    • vmendoza03
      • Jun 2014
      • 16
      Thanks blackcat!
      But the problem is I cannot find any drivers on the internet Do you know where to see one?
        • 22914
        Perhaps you can find something here? I did.:
        Downloads | Drivers | Toshiba Copiers
        • TheOwl
          • Nov 2008
          • 1733
          From the server, go into the Print Properties and then go into the device settings tab.
          You should find a selection there called something like "Update Automatically". Disable that and see how you go.
          • vmendoza03
            • Jun 2014
            • 16
            Hello,
            I tried to download the driver: Windows e-Bridge Universal 2 PCL/PS 32/64 Bit Driver for my 4555C but it also gave me the Universal driver.
            I still tried it but same results it is still slow. Thanks for your reply!
            • vmendoza03
              • Jun 2014
              • 16
              I did this but still it is slow thanks for your reply!
                • 22914
                If you don't want the Universal driver, don't download the universal driver. You got exactly what you requested. =^..^=
                  • 8060
                  I recently installed 24 eBX copiers on a large municipal network with the aid of the local IT Manager. The driver is definitely not slow. How long does it take for the green data lamp on the copier to begins blinking? Should be about three seconds if set up correctly on the server side. Something is wrong on your set up. Do you have 10/1000 selected in Top Access/ Admin/ Network/ TCP IP?
                  How have you configured your port? LPR, Print Queue Name: print. Byte counting and SNMP status unchecked?
                  • vmendoza03
                    • Jun 2014
                    • 16
                    The port is LPR, print queue: print. Byte and SNM unchecked.
                    For the Top Access/TCP IP: it is set to auto -100MB. I changed it to 1000Base FUll. I will observe if it will be faster.
                    What does -100 mean? Can it be the cause why printing is slow? Thanks
                    • TheOwl
                      • Nov 2008
                      • 1733
                      In a network, you can have the machine auto negotiate the speed which it communicates at of set it manually such as you have.
                      10 - 10 MBit a Sec
                      100 - 100 MBit a Sec
                      1000 - 1000 MBit a Sec (Gigabit)
                      10000 - 10000 MBit a Sec (10 Gig all though MFD's aren't yet capable of this speed)
                      • vmendoza03
                        • Jun 2014
                        • 16
                        10 - 10 MBit a Sec
                        Hi guys,
                        I have tried all your suggestions here but unfortunately, none worked. Our Toshiba printers are still very slow.
                        When I try to open the printer queue on the server, I can see that an 8MB file with 5 pages is processed very slow. Its like 0.01 MB per sec. It took 20minutes for it to be printed.
                        My server is Windows 2008 Standard 32-bit while the users are on Windows 7 64-bit. I have installed both 32 and 64 bits. will it be an issue?
                        Also, I have installed the driver locally on one user's machine and pointed it to the printer IP. It worked fine but it is not in the server.
                        Any ideas guys? Thanks for your help!
                        • mckinley
                          Chief Twiddler
                          • Dec 2006
                          • 150
                          What level version of driver do you have installed? 7.###.### version & what level of firmware does the machine have?
                          Happiness Is The Road.
                          • vmendoza03
                            • Jun 2014
                            • 16
                            TOSHIBA Universal printer 2 Driver version:
                            Windows x64 - 7.771.2651.1
                            Windows NT x86 - 7.131.3450.7
                            Copier Firmware: T212FD0W1536
                            Copier Main Rom Version: 210M-72
                            Copier Scanner Rom Version: 212S-12
                            Thanks!
                            • mckinley
                              Chief Twiddler
                              • Dec 2006
                              • 150
                              V1536 firmware? that could be part of the problem, it's old, you may want to try V2101
                              I would personaly take a clone of the machine, format the HDD, load V2101 firmware, re-load the clone file.
                              The driver is upto date enough, but I've found the Universal 2 PS3 driver to perform better on some servers than the normal Universal 2.
                              Regards.
