Xerox 7845 Service mode
  • jonbonse
    • Jun 2009
    • 730
    Hi all
    Im a Ricoh tech (ex Xerox) and would like to know how to enter diagnostic mode on a Xerox 7845?
  • amraklve
    • Jul 2015
    • 17
    Re: Xerox 7845 Service mode
    What sort of functions are you wanting to access?
    Sent from my SM-G900I using Tapatalk
    • jonbonse
      • Jun 2009
      • 730
      our client has Fuser error and wanted to make sure I knew how to reset this
      • amraklve
        • Jul 2015
        • 17
        Service mode can be entered by holding 0 for 10 seconds then while still holding down the 0 key pressing start.
        6789 enters diagnostic mode 2732 enters CSE mode
        • artur
          • Feb 2014
          • 5
          it won't turn out to reboot fuser
          • Exok
            • Jun 2011
            • 750
            Unlike Ricoh you don't have to enter service mode to reset all fuser errors on Xerox. If they are having a fuser error first inspect the fuser for damaged rollers. If all looks well try a simple power off / on. If that does not correct it you'll probably have to replace the fuser.
            • jonbonse
              • Jun 2009
              • 730
              Tge machine keeps getting a 'Fuser System error' when printing say 15 pages...
              • TEKK09
                • 142
                Did you get the "Fuser System Error" resolved? I have the same problem on a WC 7970. I did notice the heat roller had a small wrinkle an inch or so from the edge.
                • seximibabay07
                  • Mar 2013
                  • 59
                  hi check the faults and post here.
                  maybe the LVPS or Sub LVPS
                  regards;
                  • TEKK09
                    • 142
                    regards;
                    I hope these are the codes you wanted. I should have included them prior. Thanks a lot!
                    310-330-00
                    310-330-00
                    312-912-00
                    377-903-00
                    377-901-00
                    377-900-00
                    • TheXERguy
                      310-330-00
                      310-330-00
                      312-912-00
                      377-903-00
                      377-901-00
                      377-900-00
                      If you are still having this error (78xx and 79xx) all you have to do is unplug the machine from power and keep it unplug for 2min - while it's unplug take fuser (R8 - behind door A, left side of the machine) out shake and install, plug and power on the machine
                      • Scarecrow
                        • Oct 2010
                        • 234
                        • rockdude
                          • Feb 2011
                          • 257
                          Please explain what Repair or Diagnostic is served by shaking the fuser ??
                            • 22801
                            hmmm will have to try that... I've just been slamming them on the floor a few times!
                            • TheXERguy
                              Sometimes small particles (waste toner, paper etc) stuck inside the fuser that causes fuser to not heat properly or causes jam and ghost jam
                              Sent from my SM-G955W using Tapatalk
