Error 045-310 on Screen, 027-741 + 127-210 on Errorpage
Tags: None
Re: Error 045-310 on Screen, 027-741 + 127-210 on Errorpage
Stefan seems to be romanian name.
Before you go to the software reload, open the Fiery cage and reseat all connectors and
memories dimm. Be sure you connect the right cables to the right ports: scan to scan print to print.
Probably I have the 1.2 sys software version - send me mail. -
SHammer
Did you checked the Fiery hdd ? May be some bads cluster on it and the software crash.
Send me a photo with the white label with 3 serial numbers on it.
This label is on Fiery cage.Comment
