Dear all,
I need your help regarding error on WC7428, I'll try to explain what happened,
The device is reset for a moment by himself and no longer wanted to boot a system error 116-324 occurs and it stuck. I suspect the problem with the hard drive.
My question is whether the system can be cloned from another of the same device and put it on a new hard disk, whether it will work or what other steps.
Thank you in advance and best regards,
Darko
Darko
